| Register | vBPicGallery | Invite Your Friends | FAQ | ChatBox Full | Donate | Members List | Social Groups | Calendar | Mark Forums Read |
Thread Tools |
#1 |
That DI Guy
Car: Black 2001 2.5RS
This thread will be used to document the progress of the DirtyImpreza RS rally car.
Recent Video Clip: Recent Still Pic: ![]() Recent Action Pic: ![]() Purchased: 7/16/07 Table of Contents: 7/17/2007 - Sticker Removal 7/21/2007 - Applied DirtyImpreza Decals 7/27/2007 - Trunk Stripping 7/28/2007 - O2 Sensor Fix 8/02/2007 - Knock Sensor Fix 8/02/2007 - Trunk Sound Dampening Removal 8/09/2007 - Hood Vent Cover Removal 8/11/2007 - Rear Cabin Stripping 8/16/2007 - Cabin Carpeting / Console Removal 8/20/2007 - Cabin Sound Dampening Removal 8/25/2007 - Rear Seat / Rear Dash Dampening Removal 9/02/2007 - Trunk / OEM Wing Debadging 10/27/2007 - RallyArmor 3/16 Front Skidplate Install 11/14/2007 - Team Dynamics ProRally1 Wheels 11/25/2007 - Soltek HID Install (First Position) 12/18/2007 - DirtyImpreza Windshield Banners 12/28/2007 - OEM Stereo / Front Speaker Removal 1/9/2008 - First Time In The Dirt / Punctured Oil Pan 1/16/2008 - Repairs Planned 1/19/2008 - AUX HID Light Wiring 1/22/2008 - Jackson Rally Main Lightbar Installed 1/25/2008 - Emergency Rally Spill Kit 1/28/2008 - Sparco 6 Point HANS Compatible Harnesses 2/2/2008 - Clutch / Flywheel Replacement 2/13/2008 - Gorilla Acorn Bulge Black 3/4" HEX (19mm) Lugnuts 2/24/2008 - Custom OEM HID Brackets 3/28/2008 - RA Roof Vent Delivered 5/1/2008 - Second RS Purchase 5/10/2008 - Second GC Gutting / Stripping 5/20/2008 - Windows Pulled / Trunk Removed 6/11/2008 - Doors Removed / Scraping / Coilovers Arrive 6/18/2008 - Dashboard Removed / Airbags Out 6/26/2008 - Seam Welding Prep 7/2/2008 - B pillar Plates 7/8/2008 - A/C and Cruise Control Removed 7/19/2008 - Rally Tires Mounted 8/27/2008 - Trunk Seam Prep / Coilovers Installed 9/15/2008 - Main Cage Bars Bent and Tacked In 9/17/2008 - More Cage Bars Fitted / Top Of Cage Welded 9/24/2008 - More Cage Work 9/25/2008 - More Cage Progress - Motor Pulled 9/28/2008 - B Pillar X Welded 10/9/2008 - Front Strut Plates and Bracing / A Pillar Gussets 10/14/2008 - A Pillar to Front strut tubes / Interior Seam Welding 10/23/2008 - Transmission Pulled / Underbody Seam Welding Prep 10/26/2008 - Doorbar X's / A Pillar Reinforcement Bar 10/27/2008 - Final Underbody Seam Prep / OEM brakelines removed 11/6/2008 - Jackson Rally Rollcage Install Complete / Seam Welding Complete 11/30/2008 - Safety Equipment from Safe Drives 12/2/2008 - Engine Bay Cleaned and Degreased 12/10/2008 - Roll Cage / Engine Bay / Cabin / Trunk Painting Complete 12/22/2008 - Old RS to New RS Everything Swap 1/27/2009 - Cage Film / Odds and Ends Things 2/15/2009 - Quick Release Steering Wheel Install 3/5/2009 - Valve Adjustment / Header Stud Repair 3/7/2009 - Project Rally RS's First Time in the Dirt 3/15/2009 - RS Trunk Debadged 3/18/2009 - Logbook Issued 3/25/2009 - Axle / Torn CV Replaced 3/29/2009 - Painted A Pillar Support Bar 4/3/2009 - Vinyl Graphics Installed 4/4/2009 - RA Roof Vent Installed 4/9/2009 - Group N Mounts / Catback Exhaust 4/14/2009 - Brakes Inspected / RA Vent Latch / Scissor Jack Modification 4/19/2009 - California City Shakedown 4/25/2009 - Glen Helen 2 Rallycross Footage 5/3/2009 - Roof Scoop Installed 5/18/2009 - RallyArmor Mspec Mudflaps 5/22/2009 - Fender Wiring Protection 5/24/2009 - Day Stages Bumper 5/30/2009 - First Car Show 6/2/2009 - Proper Alignment 6/20/2009 - Front Grill Aesthetics 7/7/2009 - Hoodpins / Endlinks / Windshield Banner 7/26/2009 - HID Wiring (Re)Installed 8/10/2009 - Autometer Pro Shiftlight 8/23/2009 - Used Michelin Rally Tires 9/11/2009 - Cobra Imola Pro Seats 9/20/2009 - Cal City Rally X 11/6/2009 - Axle / CV replacement 12/6/2009 - Forman Performance Opening / SCIC Photoshoot 12/11/2009 - Sparco 6 Point Harness Install / Trunk Anchor Mounts 3/20/2010 - Ghetto Air Horns Installed 3/27/2010 - Terratrip 202+ Rally Computer / DSI Box Installed 3/28/2010 - Peltor FMT110 / Hella Map Light Installed 4/1/2010 - Personal Safety Items (Helmet / Shoes) 5/20/2010 - DRTY RS License Plates 6/13/2010 - New Plates On / Soltek Light Covers 8/3/2010 - HANS Posts / Race Suit 8/17/2010 - Feal Suspension Coilover Servicing Modifications: Engine: Stock EJ25 K&N Drop-In Filter Custom Magnaflow Catback Suspension: AllWheelsDriven Bilstein/H&R 40mm Gravel Coilovers RalliTEK Rear Swaybar Wheels / Tires: Team Dynamics Pro Rally 1 Gravel Wheels (White) 15x6 +40 Hankook Ventus R201 G51 Rally Tires 195/65x15 Interior: Jackson Rally FIA Spec Roll Cage Sparco 6pt HANS compatible harnesses NRG Innovations Short Hub NRG Innovations Quick Release NRG Innovations 350mm Sport 3 Steering Wheel Autometer Pro Shiftlight Cobra Imola Pro Seat (Driver) Cobra Imola Pro GT Seat (Co-Driver) Cobra Alloy Sidemounts Sparco Seat Bases Terratrip 202+ Rally Computer* Peltor FMT110 Intercom* Hella Codriver Light* LifeHammers (x2)* Exterior: Jackson Rally Custom Stainless Lightbar Rally Armor Mspec Urethane Rally Mudflaps Rallispec Roof Scoop RA Roof Vent JDM RS Roof Skin Mesh Radiator Screen Lighting: Soltek 4" Fuego HID Driving Lights (x4) Soltek 4" Fuego HID Wide Cornering Lights (x2) Soltek LED Interior Domelights (x2)* Misc: Rally Armor 1/8" Front Skidplate Braille Endurance Series B6034 Battery Group N Motor Mounts Group N Transmission Mount Results: 9/20/2009 - 3rd Place Overall (3rd Place R4) - California City Rally X 4/25/2009 - 3rd Place Overall (3rd Place R4) - Formula Rally X (FRX) Glen Helen 2 Rallycross 3/7/2009 - 7th Place Overall (7th Place R4) - Formula Rally X (FRX) Glen Helen 1 Rallycross 4/4/2010 - 3th Place Overall (3rd Place R4) - Glen Helen "Follow the White Rabbit" Rallycross Weight Reduction: 1.00 lbs - Removed Hood Vent Covers - Scale Reading 2.40 lbs - Removed Trunk Sound Dampening Material - Scale Reading 2.00 lbs - Rear Seat Support Beam - Scale Reading 4.85 lbs- Rear Side Impact Support Beam - Scale Reading 4.15 lbs - Rear Speakers - Scale Reading 5.40 lbs - Rear Side Panels (x2) - Scale Reading 2.90 lbs - Rear Dash and Hardware - Scale Reading 9.60 lbs - Rear Seat Foam Backing - Scale Reading 10.40 lbs - Rear Seat Bench Foam - Scale Reading 25.25 lbs - Spare Tire - Scale Reading 1.55 lbs - Trunk Carpet - Scale Reading 3.30 lbs - Trunk Carpet Siding - Scale Reading 5.20 lbs - Jack and Spare Hardware - Scale Reading 4.15 lbs - Trunk Floor - Scale Reading 2.80 lbs - B and C Pillar Molding - Scale Reading 5.75 lbs - Rear Seatbelts - Scale Reading 1.85 lbs - Plastic Door Moldings - Scale Reading 1.95 lbs - Plastic Door Sub-moldings - Scale Reading 6.40 lbs - Center Console + Hardware - Scale Reading 3.55 lbs - OEM Subwoofer - Scale Reading 5.85 lbs - Cabin Carpet - Scale Reading 8.55 lbs - Main Cabin Sound Dampening Material - Scale Reading 9.65 lbs - Stereo and Front Speakers - Scale Reading --------------------------------- 128.60 lbs Total Removed --------------------------------- Weight Offset +18.55 lbs - Rally Armor 1/8" Front Skidplate --------------------------------- 110.05 lbs Net Weight Savings
\m/ Aaron ![]() America's / Discount Tire Company|AMSOIL|Rally Armor Mudflaps|Soltek Light Systems|Team Illuminata|Team Dynamics Racing|All Wheels Driven|RalliTEK|GrimmSpeed|Braille Auto Development|Jackson Rally|Redline Rally|Millennium Motorsports|Team O'Neil Rally School|Safe Drives Last edited by 409industries; 08-20-2010 at 03:17 PM. |
#2 |
That DI Guy
Well, i picked up a Black 2001 Subaru Impreza RS tonight for $6800. I bought it off a very nice guy named Kevin that works at SRT Motorsports in Yorba Linda, CA. I was stoked that he was interested in my plans for the car even after he sold it. Way cool. I can tell this is the beginning of a very big project, but i cant wait to document all the steps along the way. So heres my first thoughts:
The Bad -The car has 120K miles on it -The clutch is slipping. -Passenger side front 1/4 panel has a nice dent in it. -The clear coat is coming off all over the rear of the car. -CEL is on because of a bad o2 sensor. -5th gear likes to grind a bit when it goes into gear. (eep) -The car is still registered in Illinois, so its out of state -The brakes pads are dead and the brakefluid hasn't been changed in a loonnng time. -Driver's side window doesn't roll up on the track without help. The Good -The car is black. I like black cars. -The seller gave me a replacement Exedy clutch that he bought, but never installed. -The Timing Belt was replaced at 94K miles -The Oil / Diff fluids have been changed recently -New spark plugs and plug wires -The interior is in very good shape -There are Hellas (500's i think) installed -Not a salvage title ![]() First night in its new home! Oh yeah, and the original owner sprung for the imitation CF trim... niiiice... So first things first, i gotta get the damn thing registered in California, thats going to suck, since I have to get it inspected by the DMV since they have to actually SEE the VIN number, and it needs to be smogged. Then once i can legally drive it around, ill go get that clutch replaced... The adventure begins... |
#3 |
Congratulations, the car looks clean. I'm happy for you. I know you were looking for a while to find one. Can't wait to see what your going to do to this monster.
#4 |
Car: Silver 2007 WRX
Nice buy, can't wait to see what you have in store for it. I think you should spring for getting the entire body stitch welded and have a roll cage installed (tis what i want to do if i turn my wrx into a dedicated rally car).
#5 |
nice buy. I don't know why I'd ask, but is this going to be a rally/rally-x car or do you have other plans?
photography.mattbasile.net |
#6 |
That DI Guy
The ultimate goal for this car is PGT stage rally competition (even though i havent figured out how im going to be able to drive in PGT w/o any experience yet)... but ill figure that part out soon enough.
First things first though. The car needs to be smogged and registered in CA. Its still from out of state with IL paperwork. Not rad... since i have to figure out when im going to have time to get the damn thing looked at by the DMV, then theyre going to rape me because its from out of state so i'm going to have to shell out a few bucks. The car is definitely going to be caged, with a FIA spec roll cage. I already have an agreement with Coyote Fabrications in Orange, CA to do the work. The stitch welding part is up in the air, its a huge undertaking. I may have the strut mounting points reinforced, but to do the entire chassis might not be feasible. AP Boss in Los Alamitos would be doing the stich work. Well see. Theres a lot of small steps to take before i can take on the bigger aspects of the project. |
#7 |
Blue 2002 WRX Wagon
Can't wait to see this RS in full DI paint/decal livery!
Add yourself to the Dirty Impreza member map! | My Flickr | My Facebook | My Youtube | My XBOX Live | My Twitter | My Steam Profile
#8 |
That DI Guy
Got home from work today. Shouldnt drive the car on the street since theres a sheriff station literally across the street from me. The car has no plates, no registration and no insurance... yet.
So i took to the spot in my apartments where i could plug in my shop vac and clean it out a bit. Turns out i can subtract about $0.76 off the price of the car... BOOYA! ![]() After cleaning out the trunk I noticed that there is no factory jack in the side. no biggy, ill be getting a different one anyway. i wiped down the insides and things look much better. I had to get rid of the stickers that were on the car already. ![]() I didnt have any DI stickers on me (doh!) so ill slap some on tomorrow. |
#9 |
Southwest Regional Moderator
The girl looks really good! I wish I had mine but alas I dont have the cash. Hope you do us all proud!
Blue '03 Impreza WRX |
#10 |
Car: NPB 07 2.5i
Aaron, you're really making me want to do this to my 97 OBS and make my 03 my daily driver. Why did you have to go and get a GC
looks good and can't wait to see how it comes out Zebra
Woods - 1 Rex - Gone THE FOZZ
#11 |
Sweet car. I need to get an RS I can rally. My WRX hates me.
2002 Aspen White WRX :unamused: 1999 Grand Am GT :unamused::unamused: Never argue with stupid people. They will bring you down to their level and then beat you with experience. |
#12 |
Car: Green 2000 2.5RS
Out of state shouldn't be a big issue. Mine was from AZ and I had no problem registering it.
2008 FRX & CRS Street Mod 4 Champ SPONSORS: Rally Innovations ¦ Function Drinks ¦ Team Illuminata ¦ Rally Armor ¦ L and E Fabrication ¦ Corrupt Motors |
#13 |
That DI Guy
Yes the STi is getting a bit fussy (strange steering clunk?), but i've been trying to be nice to her. I know shes happy to have the RS around so i can beat the crap outta her instead.
#14 |
this is going to be an awesome car.
It would be good to have a timeline and milestones to hit so you know if you're on or off track with schedule. I would love to see this car in a stage rally. `Gus
Read about me: psgevo.blogspot.com Read about us: projectsologear.blogspot.com Visit us: www.projectsologear.com |
#15 |
Authorized Vendor Silver 2004 WRX
well look what I found for you on CL today...
http://sfbay.craigslist.org/sfc/pts/376823920.html just in case you want some spare parts cheap
![]() Team BLOG: http://UP2MTNS.blogspot.com/ Lassa Rally Tyre Vendor Sponsors: www.ProjectSoloGear.com | www.LandEFabrication.com | www.RedlineOil.com | www.FineLineImports.net | LASSA http://rally-tire.com/ (New!)| www.GrimmSpeed.com | www.cobbtuning.com | www.fealsuspension.com | http://www.extremedimensions.com (New!) | www.Carbonetic.net (New!) |
