Go Back   DirtyImpreza Forums > Video & Picture Forums > Member Journals
Old 08-16-2010, 11:57 PM   #1
PlummRS
Rally Status Roughneck
PlummRS's Avatar
Send a message via MSN to PlummRS Send a message via Yahoo to PlummRS
Default From broke to Bangin
HI,
I'm back! been gone for a while, so here's a little bit of what's been happening in the life of me...
Quit school after three years, worked for the steel workers union painting pre-cast concrete outhouses, got laid off for the winter and decided to be a lifty (greatest phuggin 5 months of my life!), spring rolled around and no callback from the union = 1 broke muhfugga... mid summer my grandpa died so I moved to Eastern Montana to help out my grandmother and ended up finding work in the oil patch = not so brokeded anymore!!!
I have a PSM 2005 2.5RS:
fiberglass wrapped Borla Replica Header
K&N OEM replacement filter
555 Open Source Tune
Dark Performance 'Super-wide' mudflaps
DIY Snorkus Delete
Custom red Painted Grille
White painted OEM wheels
Debadged trunk
Blacked out tails
Red Interior Trim (gonna flock that **** at some point)
Rallitek front Shifter Bushings
Torque solutions rear shifter bushing
whiteline 22mm front sway bar
whiteline subframe lockdown bolts
whiteline steering rack bushings
whiteline rear diff support lock bushings
Kartboy solid front and rear endlinks
rallitek plug wires
8mm phenolic intake spacers (grimmspeed)
exedy stage one organic clutch
ACL race main & rod bearings
whiteline positive shift bushings
perrin LCP
04 STi Pink Struts/springs
white Flossy weighted shift knob
Pioneer bluetooth head unit
Cell signal booster
Weather tech all weather floor mats
Enkei RPF1 5x100 18x8.5 wrapped in Hankook Ventus Evo V12s
Primitive Light bar, home to a set of Hella Rallye 1000 Black Magics and a set of PIAA 520 Ion Crystal fogs
I picked up a '79 BRAT that will get the engine & tranny out of the impreza, the Impreza will in turn be getting a forged, stroked ej205 running a Painless style V-mount system with a big Comp Turbo running on adaptronics engine management mated to a dccd 6mt that will eventually be swapped for a close ratio sequential dog-box
I also picked up a 78 1400DL wagon that will get an ea81/2T
~Jordon
Guess who's back muhfuggas!
my Member's Journal
~Jordon
PlummRS is offline   Reply With Quote
Old 08-17-2010, 09:16 AM   #2
Bubba02sti
Colorado Mob Boss
Bubba02sti's Avatar
Send a message via MSN to Bubba02sti
crank pully isn't really any sort of gain in pefromance... and IMO the mishimoto radiator is better... other then that it sounds like you have a good list going
Originally Posted by coldturbo
"The AP is like a suit from Sears off the rack. It will fit, it will look good and will be appropriate. A OS tune is suit from Italy made by Armani. The Armani will be made to YOU, out the finest cloth and will make bitches fall in your arms. Do you want a Sears suit?"
Bubba02sti is offline   Reply With Quote
Old 08-17-2010, 10:56 AM   #3
PlummRS
PlummRS's Avatar
Thanks bubba! and even so i'll probably still go for the lightened crank anyway haha
i guess i better find out how the CXracing and Mishimoto compare in price!
my Member's Journal
~Jordon
Old 08-17-2010, 12:00 PM   #4
RS MN
RS MN's Avatar
crank pulley is ok, but a lightened flywheel would be better,
from what i hear (i keep hearing contradicting opinions) the stock crank pulley is heavy for a reason, its also called a harmonic balancer for a reason lol. so i say keep the crank pulley stock and get a lightened flywheel, you will lose more weight off the drive system than you would with the LCP, and i havent heard anything bad about doing it.
good luck with the build!
-Joey
a passion for rally makes a heroin addiction look like a craving for a salty snack.
RS MN is offline   Reply With Quote
The Following User Says Thank You to RS MN For This Useful Post:
Old 08-23-2010, 11:35 AM   #5
PlummRS
PlummRS's Avatar
ok, so i've decided that since it is the start of yet another year of college, i'm going to spend my free time working on DIY projects for Willow
starting with:
Home built radiator shroud (there is a great NASIOC writeup on this)
Changing the Guage pod, key ring, HVAC and radio from green to red always wanted to do this and i found a really good writeup on NASIOC so i'm going to go for it
then going for a DIY rear diffuser that a fellow BSS member is also trying
and a cheap temporary oil pan skit plate out of the stock plate from an '85 suby wagon!
my Member's Journal
~Jordon
Old 09-10-2010, 02:35 PM   #6
PlummRS
PlummRS's Avatar
Hyalite Canyon Bozeman, MT run!
my Member's Journal
~Jordon
Old 09-19-2010, 09:09 PM   #7
PlummRS
PlummRS's Avatar
Mocked up DIY radiator shroud
transfered template to aluminum, now i just need aluminum snips to cut it out
ordered my custom DP 'superwide' mudflaps!
my Member's Journal
~Jordon
Old 09-28-2010, 09:46 PM   #8
Lincx
Lincx's Avatar
Did you cut that metal piece yet? Post pics!
BTW nice decal in mirror!
Lincx is offline   Reply With Quote
Old 09-28-2010, 09:53 PM   #9
PlummRS
PlummRS's Avatar
not yet! I am off at College right now and forgot my Dremel at home, but good news, i'm headed home this weekend so hopefully i'll have it done by Monday, Pics will be added right away!
my Member's Journal
~Jordon
Old 10-02-2010, 09:03 AM   #10
em99sport
S. Atlantic Regional Moderator
em99sport's Avatar
'11 STI, '00 L sedan
While the pulley might not be worth whp/tq, some folks like a quicker-revving engine. Swapping a crank pulley is much less involved than a flywheel. If you're doing the clutch anyway, do the flywheel. If not, consider the pulley.
Wrong. It is better to leave recommendations to those who know what they're talking about. SoA has confirmed the crank pulley is not a harmonic balancer.
em99sport is offline   Reply With Quote
Old 10-03-2010, 08:25 AM   #11
Paul.Aspen
Paul.Aspen's Avatar
hey brotha! car looks good! keep it up!
Paul.Aspen is offline   Reply With Quote
The Following User Says Thank You to Paul.Aspen For This Useful Post:
Old 10-03-2010, 05:52 PM   #12
RS MN
RS MN's Avatar
...from what i hear (i keep hearing contradicting opinions)...
exactly why i said this, sir. no need to insult
-Joey
Old 10-07-2010, 07:38 PM   #13
PlummRS
PlummRS's Avatar
ok so if the crank pulley is not in fact a harmonic balancer, i'm going to re-add that to the list of definite to-dos!
Thanks Paul! (I assume you're the same Paul from BSS?)
Update, i am working on cutting out the shroud, but the aluminum likes to eat my dremel bits :(
my Member's Journal
~Jordon
Old 10-17-2010, 04:45 PM   #14
PlummRS
PlummRS's Avatar
Default New MudFlaps and DP stickers
my Member's Journal
~Jordon
Old 11-04-2010, 06:22 PM   #15
PlummRS
PlummRS's Avatar
A little bit dirty
new vinyl
my Member's Journal
~Jordon
