Results 1 to 2 of 2
Thread: Delta Cam 2000 Grind Photo
    Default Delta Cam 2000 Grind Photo
    This photo shows the stock 2.5 SOHC camshaft lobe profile, and the newly ground "2000" grind on the closer side to show how we are able to acheive more lift and duration while grinding a lobe down.
    Very hard to explain over the phone.
    Registered Member 052pnt5RS's Avatar
    Feb 2009
    Cuyahoga Falls, OH
    26
    Looks like an offset grind?
  4. Don't like seeing these ads? Register on the DirtyImpreza.com forums today - Click Here
