Page 1 of 3 123 LastLast
Results 1 to 15 of 32
Thread: Lift spacer templates & install pics
    Default Lift spacer templates & install pics
    *Edit: 93'-01' Impreza rear template added below...
    Hey guys,
    I've been seeing a lot of people asking for a template to build their own lift spacers so I thought I'd share my templates with you guys. These dimensions are the dimensions I had my spacers cut to and they fit perfect! I'm sure there is some room to fudge if you don't get it exact but this will get you started. These templates were for my 97' Legacy Outback, which I believe is the same as the Foresters, 95'-00' Legacies, and Imprezas/WRX's 02'-07'. Don't quote me on that as I'm not 100% on the other fitment but I'm sure someone can chime in whether that is correct or not. I also have the spacers for the rear 93'-01' Imprezas and will get those posted soon.
    Edit: A member just noticed that I am missing a couple dimensions on the rear template. The distance from the stud hole center lines to the outside of the spacer is 0.6563", or 21/32". And the distance from the stud hole center lines to the center hole is 0.75", or 3/4". And on the front spacer template, the distance from the stud hole center lines to the center hole is 0.65625", or 21/32". Hope these help you guys get your scoobs lifted!!!
    *Disclaimer*
    Take these templates and do with them what you want. I am in no way responsible for lift spacers damaging your car or you damaging your car for installing them or trying to make them. Do your research and never work outside your skill level or your means.
    Attached Images Attached Images
    Dream catchers work... if your dream is to be gay!
  2. #2
    Here are some pics of my spacer install. You can see I used a lock nut to secure the bolt to the top hat and just counter-bored the stud hole in the spacer to accommodate the nuts. I also have a slight chamfer (~1/8") on the inside edge of the center hole to allow the spacer to fit totally flat.
    I used some M8x1.25x50mm Grade 10.9 Fully-threaded bolts with matching lock-nuts and just reused the stock top nuts. These can be found on Ebay for quite cheap. You will not have to break down the front strut assembly (or at least I didn't have to) but you will need to take apart the rears to get the stock studs out. I used a socket behind the stud and a BFH to knock them out.
    Hope this helps those of you who do not have the money to buy spacers from the venders but have some fab skill and drive to do it yourselves!
    Robbie
  3. #3
    Jun 2009
    Torrance, CA
    17
    This is great thank you so much for the template. I'm about to get some HDPE to start this but was worried about cutting them right. Speaking of cutting what did you use to cut theses?
  4. #4
    I had mine cut on the CNC at my work but I did make a previous set that I just cut with a jig saw and smoothed with a disc sander and then a drill bit to drill the holes. Might want a file on hand if your OCD but they won't be seen so they don't need to be perfect.
  5. #5
    Registered Member bucky685's Avatar
    Aug 2010
    Dubuque,IA
    136
    Awesome! Can anyone confirm if they will work on a '06 impreza OBS?
  6. #6
    Registered Member Herger's Avatar
    Sep 2011
    Micro Soda
    129
    Is there any reason why you didn't bolt the spacer to the strut? Thanks for posting your templates up.
    Steve
  7. #7
    cuz it gets sandwiched between the tophat and the body.^^
    Quality remanufactured, rebuilt, and used subaru engines and other parts: http://www.ssisubaruspecialists.com/
  8. #8
    disregard my pm. This is awesome. Thanks a ton! I'll let you know how it goes with my 97 outback sport
  9. #9
    Bucky, these should fit your 06 OBS. You have the same suspension setup as the wrx's in that MY. You'll probably want to do some searching around just to verify they'll work but I'm pretty sure they are the same. People bolt wrx and forester suspension to outbacks with no other mods.
  10. #10
    Aug 2010
    Dubuque,IA
    136
    Awesome, I'll have to get a set cut next time i have parts cut at the waterjet.
  11. #11
    Bumping this up for those 93'-01' Impreza guys! Here is your rear template! You will need this template for the rear spacers and the above front template for your front spacers.
    Now let's see some lifted scoob pics!!!!
  12. #12
  13. #13
    Hi, back again. So with the help of this message, I decided to undergo building my own lift kit, which is quite a large overstatement, considering that the work has mostly come down to getting friends to help me make the parts.
    Anyhow, it's finally happened. Money has been exchanged, time has been committed, and I'm beyond excited.
    I just want to do one final verification. I'm thinking that I read somewhere that the 97 outback legacy and outback impreza sport have the same front top hat configurations on the front, but I'm really not positive. Can anyone give me a quick confirm on this?
    Thanks.
  14. #14
    Yes. The fronts are the same, the rears are different.
  15. #15
    Default Thanks
    Thanks this is excellent, any idea to print the image 1:1 and use it as a template?
