Results 1 to 3 of 3
Thread: Lifting 98 legacy sedan
    Default Lifting 98 legacy sedan
    hey i was recommended to come to this site, i want to lift my 98 legacy sedan, ive been told forester struts and springs, i just want to make sure if i do it, that its right. What do i need to lift it?
    Registered Member CjZeppy's Avatar
    Sep 2010
    Hanover, PA
    40
    heres a link that'll solve everything!
    http://www.sl-i.net/FORUM/viewtopic.php?t=14185
    I'd go with some OBS struts and springs. They bolt in easy and are not difficult to find!
    Quote Originally Posted by edyer21 View Post
    It depends how high you want to go...
    subtle solutions or jackson rally strut top spacers (1" lift)
    OR (anything more than 1" you'll need a camber bolt set for the front also)
    96-99 outback struts, your leggo springs are the same... (1.5" lift)
    OR
    96-99 outback struts with gen 1 forester (98-02) springs (you'll need the forester upper spring perch for the front too) 2ish" lift
    OR (you'll need camber kit for front and probably rear too for this one)
    gen 2 forester (2003-200 complete strut assemblies (strut, spring upper spring perch, and top hats)... 3+" lift
    gotta run but there's more info here and around. . . .
  5. Don't like seeing these ads? Register on the DirtyImpreza.com forums today - Click Here
