Results 1 to 15 of 15
Thread: thinking about lifting my wagon
    Registered Member bmcgov1209's Avatar
    Dec 2009
    Blacksburg, VA
    15
    Default thinking about lifting my wagon
    I'm new to these forums and have a few questions about lifting my 04 wrx wagon. I searched some, but couldn't find a good answer to my questions.
    I recently moved from the beach to the mountains and ground clearance has become an issue. I'm currently on lowering springs, but would love to lift the car 1-2" above stock and put a bigger tire under it.
    My car will be 95% DD and 5% dirt/gravel roads and snow driving.
    Will OBS springs/struts bolt right in and give me the lift I'm looking for?
    What other options do I have without spending a ton of money(<1k)?
    Senior Dirty Member TOI's Avatar
    Sep 2009
    sherman Tx
    1,500
    im new to this too, but i think getting stock springs and slipping in a JR lift would do the job
    Garage Fab Innovations
    Regular Contributor GClark's Avatar
    Jul 2009
    Maine
    306
    Yeah I say just do the Jackson Rally 1in spacer kit. Its only 250 so you can spend the rest of the money on tires and lights!
    Will the JR kit just bolt in with no other modification? If so that does sound like a good cheap option.
    DirtyImpreza Badass Newk_Rally's Avatar
    Jun 2008
    Long Beach/ Los Angeles
    2,773
    yes it will =D they're out of stock right now but should be getting more soon
    1st Place 2009 So Cal FRX SS4
    2nd Place 2010 So Cal CRS SM4
    Quote Originally Posted by Guero View Post
    Credit: \ˈkre-dit\ N. How far you are willing to get your head up the Federal Banking System's ass.
    Quote Originally Posted by GClark View Post
    The JR kit and tires are the only lift on your car, correct?
    Jul 2009
    Maine
    306
    Si errr CorrectO.
    Registered Member baconpocket's Avatar
    Jan 2010
    Bloomington, IN
    8
    Default similar sich
    i've been scouring DI and NASIOC and foresterforums trying to figure out what my best option would be to do a very small lift on my 02 wrx wagon. i'm thinking of trying to get some geolander ats 215/60-16 to fit without rubbing. i'm pretty sure that OBS springs of a similar vintage can be used to give a very mild lift ~0.5 inch. this may be offset by the extra weight of the turbo hardware upfront, combined with a softer spring rate. i can't find the spring rate for the OBS (maybe someone can post it) but i believe the WRX wagon is F/R 163/132
    see http://www.northursalia.com/techdocs/spring/spring.html
    another option i've come across is the 1/4 to 1/2 spacers sold by paranoid fabrications http://www.camotoy.com/products/saggybutt/index.php
    maybe you're looking to go a bit higher than i had in mind, not sure but hopefully this helps you or someone else
    S. Atlantic Regional Moderator em99sport's Avatar
    Mar 2008
    Hope Mills, NC
    220
    Quote Originally Posted by baconpocket View Post
    Just keep in mind that these are for the rear only.
    Jan 2010
    Bloomington, IN
    8
    Quote Originally Posted by em99sport View Post
    i could be wrong but when i scroll to the bottom of that page, i see front spacers.
    so maybe one could mix and match to level their ride?
    Registered Member subie_drift's Avatar
    Apr 2008
    Avondale, AZ
    101
    i was thinking the same with the spacers but i think the most durable lift would be the jackson rally kit. But not to thread jack but instead of using a spacer has anyone used bigger springs with the stock shocks to achieve a lift. so ull get lift and more travel which would be nice. jus throwing out sum ideas.
    Jan 2010
    Bloomington, IN
    8
    my main reason for thinking about a lift is that i'd really like to fit the geolander at/s in 215/60-16 (the smallest all terrain on the US market). i want to do this because i want a tire that can handle just a tiny bit of snow and ice well, while mostly seeing dirt and street. i feel like snow tires will just disintegrate with too much street and dirt.
    here's some info that i've compiled regarding tire sizes:
    use size radius diameter tread width
    stock 205/55-16 12.41 24.87 8.07
    snow 205/55-16 12.84 25.68 8.07
    - i've seen many reports that these will fit with no rubbing at stock ride height
    gclark fitted 215/xx-15 d~27.1 tw8.46
    with just jackson rally 1 inch spacers (which in my personal opinion cost more than i'm trying to pay for such a small change)
    the geolander at/s
    215/60-16 13.07 26.15 8.46
    with a radius change of +0.66 (13.07-12.41) in from stock these tires alone will lift the car 2/3 inch. the width increases by 0.39 inch which would be divided by two laterally.
    if these do rub, and depending on where they contact, the problem may be averted by using stock forester wheels which have a +48 offset rather than the impreza +53 or +55
    any of you guys have a forester handy? you could simply fit the stock 16 inch wheel/tire combo from the forester onto your impreza and see if it rubs anywhere
    Jan 2010
    Bloomington, IN
    8
    addition to the above post. this commenter on nasioc claims that he sees no rubbing with a 1 inch larger diameter tire on stock sedan suspension, minor rubbing in back on a stock wagon. anybody know the actual measurements of the named rally tires?
    quote (user wrxinfx):
    I run the Michelin FB-80's from Sube sports on a second seto of take-off WRX rims. They don't rub on my sedan, although I ran in a brisk gravel TSD rally with a '03 wagon with the same tires on 16" steelies from TireRack and he noticed some rubbing in the rear when fully compressed.
    Speaking about the tires - they are great. The lateral reisistance at speed is great, they are just as predictable as everyone says. They are very loud on the road though, and I wouldn't run very far on tarmac as it will cause unessesary wear.
    As for a spare, another consideration is at they are about 1" larger in diameter. So carring a regluar full-size spare could be a problem due to the uneven tire sizes. Although - if you look, the factory "donut" spare is smaller in diameter than the OEM tires, so maybe tire diameter is not such a big issue.
    Casey
    /end quote
    Quote Originally Posted by bmcgov1209 View Post
    I'm looking to do the same thing as you. My car is on coilovers right now. I'm thinking that my best option will be to find someone who wants to trade their stock suspension for my coilovers. Throw some JR spacers on there and some bigger tires (size?) and i should be set.
    Oct 2011
    Czech Rep.
    11
    Hi Im thinking about lifting my wrx wagon 2001. Can i use forester springs only on my wrx wagon ? Will it fit ? I know it will be just a small lift, but better some lift than no lift
